tarvis nivan 1600 koneeseen kiristys monentit??
en löytänyt mistään...
kiristys momentit niva
Ja nuo momenttithan pitäis löytyä UKK:sta..Jaakkima kirjoitti:Samat ne on Nivassa ja takavetoisessa. Samaa 1600 cc:n konetta kun on käytetty molemmissa.
Momentteja:
Tightening torque N.m
Bolt, main bearing cap M10x1.25 80.40
Bolt, oil sump M6 7.80
Stud, breather cover M8 19.6
Nut, breather cover M8 19.6
Bolt, cylinder head: M12x1.25
preliminary tightening 39.2
final tightening 112.7
Bolt, cylinder head M8 37.2
Nut, intake and exthaus manifolds M8 24.5
Nut, connecting rod cap bolt M9x1 50.96
Bolt, flywheel M10x1.25 83.3
Bolt, chain tensioner shoe M10x1.25 44.1
Nut, camchaft bearing housing M8 21.6
Bolt, oil pump drive shaft sprocket M10x1.25 48.6
Bolt, camchaft sprocket M10x1.25 48.6
Nut, valve adjusting bolt M12x1.25 50.96
Bushning, valve adjusting bolt M18x1.5 98
Spark plug M14x1.25 37.2
Bolt, coolant pump M8 25.5
Nut, coolant jacket outlet connection M8 21.56
Starting jaws, crankshaft M20x1.5 119.56
Bolt, alternator backet M10x1.25 51.9
Nut, alternator adjusting brace M10x1.25 43.1
Nut, alternator-to-bracket bolt M12x1.25 68.6
Nut, adjusting brace-to-alternator M10x1.25 43.1
Nut, support pad-to-engine bracket M10x1.25 33.3
Nut, front support pad-tocrossmember
bracket M10x1.25 32.3
Nut, engine rear mount crossmember M8 17.6
Nut, rear support-to gearbox M8 27.4
Nut, rear support-to-crossmember M8 24.5
Siinä momentteja. Lähde VAZ 2121 Repair Manual
Osku
Osku
